Self-hosting. Immich
Программа для хранения фотографий и их обработки. Имеет возможно преобразования фотографий и видео, распознание лиц и разметка по геолокации.
По дизайну очень похожа на google фото.
Репозиторий: GitHub - immich-app/immich: High performance self-hosted photo and video management solution.
Документация: Introduction | Immich
[!bug]
В последних версиях проксирование авторизации через aithentik приводит к проблемам авторизации для мобильных приложений. Можно использовать только authentik для внешней авторизации без прослойки в traefik.
  • “{ Immich”
  • immich
    modified: 2024-10-06T00:59:40+03:00
# WARNING: Make sure to use the docker-compose.yml of the current release:
# https://github.com/immich-app/immich/releases/latest/download/docker-compose.yml
# The compose file on main may not be compatible with the latest release.
  immich-server:
    container_name: immich_server
    image: ghcr.io/immich-app/immich-server:release
    # extends:
    #   file: hwaccel.transcoding.yml
    #   service: cpu # set to one of [nvenc, quicksync, rkmpp, vaapi, vaapi-wsl] for accelerated transcoding
      - ${UPLOAD_LOCATION}:/usr/src/app/upload
      - /etc/localtime:/etc/localtime:ro
    env_file:
      - stack.env
      - PUID=1000
      - PGID=1000
    depends_on:
      - redis
      - database
  immich-machine-learning:
    container_name: immich_machine_learning
    # For hardware acceleration, add one of -[armnn, cuda, openvino] to the image tag.
    # Example tag: ${IMMICH_VERSION:-release}-cuda
    image: ghcr.io/immich-app/immich-machine-learning:release
    # extends: # uncomment this section for hardware acceleration - see https://immich.app/docs/features/ml-hardware-acceleration
    #   file: hwaccel.ml.yml
    #   service: cpu # set to one of [armnn, cuda, openvino, openvino-wsl] for accelerated inference - use the `-wsl` version for WSL2 where applicable
      - model-cache:/cache
    env_file:
      - stack.env
  redis:
    container_name: immich_redis
    image: docker.io/redis:6.2-alpine@sha256:d6c2911ac51b289db208767581a5d154544f2b2fe4914ea5056443f62dc6e900
    labels:
      - "com.centurylinklabs.watchtower.enable=false"
    healthcheck:
      test: redis-cli ping || exit 1
  database:
    container_name: immich_postgres
    image: docker.io/tensorchord/pgvecto-rs:pg14-v0.2.0@sha256:90724186f0a3517cf6914295b5ab410db9ce23190a2d9d0b9dd6463e3fa298f0
    labels:
      POSTGRES_PASSWORD: ${DB_PASSWORD}
      POSTGRES_USER: ${DB_USERNAME}
      POSTGRES_DB: ${DB_DATABASE_NAME}
      POSTGRES_INITDB_ARGS: '--data-checksums'
      - ${DB_DATA_LOCATION}:/var/lib/postgresql/data
    healthcheck:
      test: pg_isready --dbname='${DB_DATABASE_NAME}' || exit 1; Chksum="$$(psql --dbname='${DB_DATABASE_NAME}' --username='${DB_USERNAME}' --tuples-only --no-align --command='SELECT COALESCE(SUM(checksum_failures), 0) FROM pg_stat_database')"; echo "checksum failure count is $$Chksum"; [ "$$Chksum" = '0' ] || exit 1
      interval: 5m
      start_interval: 30s
      start_period: 5m
    command: ["postgres", "-c" ,"shared_preload_libraries=vectors.so", "-c", 'search_path="$$user", public, vectors', "-c", "logging_collector=on", "-c", "max_wal_size=2GB", "-c", "shared_buffers=512MB", "-c", "wal_compression=on"]
  model-cache:
  • [[Сервер Immich]]
Примечание:: Синхронизация, хранение и обработка фотографий
