The first 3D printer in 2026: five pricing tiers, prices in Russia, and the first 72 hours
Choosing the first 3D printer in 2026 isn’t the same as five years ago. Back then you bought a kit and spent six months learning to configure it; now for twenty thousand rubles you can get a box that calibrates itself and prints a decent cube within twenty minutes of unboxing. It’s harder to make a mistake — but there are more ways to overpay: for speed you don’t need, for a multicolor print you’ll enable twice, for a closed enclosure for plastics you’ll never buy.
This guide is about how to lay out the market into price tiers and understand which tier your task ends up in. All prices are retail in Russia as of August 18, 2026, collected from several stores; the spread between sellers for the same model can reach up to one and a half times, so everywhere there is a range, not a single number.
Separately about “best printer ratings.” The vast majority of such picks in search results live on the domains of the stores and manufacturers themselves. That doesn’t mean they’re lying, but the order in the list there is determined by margin, not suitability for your task. See whose domain you’re reading.
Three questions before opening a store
Half of unsuccessful purchases happen because a person chooses by specifications rather than by task. Answer yourself three questions — and half of the catalog will fall away by itself.
What will you print? Housings, organizers, holders, spare parts for household use — these are PLA and PETG, and an open frame will do. Parts that will live in a car in summer or outdoors — these are ABS and ASA, so a closed enclosure is mandatory. Minis, clock-size gears, dental models — that’s not FDM at all, but photopolymer.
Where will it be placed? An open printer is noisy and smells. An FDM machine in a living room — constant background hum of fans and odor while printing everything except PLA. A photopolymer printer in a living room — a bad idea in general, I’ll return to this at the end.
How much do you want to tinker? An honest answer of “not at all” is normal. It simply means you should skip the lower budget tier: saving ten thousand is paid for by weeks of fiddling with adhesion and calibrations.
Where the price comes from
The price of an FDM printer is built from three things, and understanding this saves more money than any review.
Kinematics. Cheap machines are “bed-slingers”: the print head moves on X, while the bed with the part moves back and forth on Y. Expensive ones are CoreXY: the head moves on both axes, the bed only lowers. The difference isn’t in marketing: with a bed-slinger, a tall part sways with the bed at speed, and you either live with artifacts or reduce speed.
Enclosure. A closed chamber is needed for one thing — so a part made of ABS, ASA, or nylon doesn’t crack from drafts as it cools. For PLA and PETG it isn’t needed, and sometimes even harmful: PLA in a hot chamber cools worse. This relates to the question “buy more expensive, maybe useful” — useful only if you actually switch to engineering plastics.
Multi-material. The prefix Combo in the name means a filament feeder box (AMS at Bambu Lab, CFS at Creality, ACE at Anycubic) that switches spools. It costs 15–30 thousand extra and prints multicolor with one nozzle — that is, at each color change some plastic goes to waste for purging. It’s not “free colors,” it’s exchanging plastic and time for appearance.
Main principle of choosing: pay for what physically changes the result for your task, not for a line in the specs. Speed of 600 mm/s is about motion geometry, not that the part will print six times faster: acceleration, cooling, and quality will still hit physics.
Tier 1. Up to 30,000 ₽ — “just prints”
Here live open bed-slingers without frills. They print PLA and PETG, one color, no enclosure.
The benchmark model for this tier is the Bambu Lab A1 mini for 19,999–21,900 ₽. Print area 180×180×180 mm, but per the manufacturer’s specs it can do 500 mm/s, nozzle up to 300 °C, and full automatic calibration. An important detail rarely mentioned in reviews: in the official spec ABS, ASA and PC on the A1 mini are labeled as not recommended — the bed heats up to a maximum of 80 °C. This is a machine for PLA/PETG, and don’t expect more.
Nearby is the Creality Ender-3 V3 KE (around 27,900 ₽; official Creality price — $279): 500 mm/s, nozzle up to 300 °C, linear rail on X. A classic bed-slinger whose strength is repairability and cheap parts, and weakness is that no one will tune it for you.
And the very bottom end is the Anycubic Kobra 2 Neo for 19,900 ₽. It works, but this is a “try it” purchase, not a full-time user.
Bambu Lab A1 mini — open bed-slinger with a 180 mm field. Photo: official Bambu Lab store in Russia
A small bed isn’t as big of a problem as it seems. 180 mm per side covers the vast majority of household tasks; everything large is still printed in parts and glued, because a single 300 mm part takes a day to print and will fail on a single bad layer.
Tier 2. 30–50 000 ₽ — a target for most people
This is the best price-to-headache ratio zone, and this is where I’d advise stopping if you don’t know exactly what you’ll do.
Bambu Lab A1 (29,999–32,900 ₽) — the same approach as the mini, but with a 256×256×256 mm bed and heating up to 100 °C. Open frame, ABS is still listed as “not recommended” in the specs.
Anycubic Kobra S1 (30,300–39,800 ₽) — the first closed CoreXY in the list. Bed 250×250×250 mm, nozzle up to 320 °C, polycarbonate enclosure, carbon filter, claimed 600 mm/s and 20,000 mm/s² (the manufacturer itself recommends 300 mm/s and 10,000 mm/s² — note this, because advertised vs. real performance differ by a factor of two).
Anycubic Kobra S1 — closed CoreXY for a little over thirty thousand. Photo: official Anycubic Russia store
Elegoo Centauri Carbon (35,000–52,000 ₽ depending on seller) — closed CoreXY with a 256×256×256 mm bed, nozzle up to 320 °C and bed heating to 110 °C, so already honestly for ABS/ASA and composites with chopped fiber. Rated at 500 mm/s and 20,000 mm/s², flow 32 mm³/s, enclosure with tempered glass, firmware — Klipper with ELEGOO OS. Weighs 17.5 kg, and this is a case where mass works for you: the frame is harder to flex.
Elegoo Centauri Carbon — closed CoreXY on Klipper. Photo: official Elegoo Russia store
Note that Elegoo has already released the next generation — Centauri 2 and Centauri Carbon 2; in retail, for example, Centauri Carbon 2 Combo costs 55,900 ₽. The first generation continues to be sold, and it often has discounts.
Bambu Lab A2L (44,900–44,999 ₽) — released June 1, 2026, an open machine with a large bed 330×320×325 mm. The nuance: the bed heats to 80 °C, supports “PLA, PETG and other non-engineering plastics,” laser module is not available. So this is “a lot of PLA,” not “expensive and powerful.”
Bambu Lab A2L: field 330×320×325 mm with an open frame. Photo from Bambu Lab announcement
Bambu Lab P1S (49,900–49,990 ₽) — closed CoreXY 256×256×256 mm, 500 mm/s, up to 20,000 mm/s², nozzle 300 °C, bed 100 °C. For several years this has been the de facto standard of a “working horse,” and it still sits beside the newer P2S.
Bambu Lab P1S. Photo: official Bambu Lab Russia store
If I were choosing, not knowing the exact task
Open frame and minimal hassle — Bambu Lab A1 for ~30,000 ₽. Ready to print ABS and ASA right away — Anycubic Kobra S1 or Elegoo Centauri Carbon. Maximum predictability and a large base of ready-made profiles — Bambu Lab P1S. All three options cover 90% of domestic and hobbyist use cases.
Step 3. 50–100 000 ₽ — what the extra payment is for
The premium here is not for print quality — it’s roughly the same at this stage — but for convenience, reliability, and multi-color out of the box.
Bambu Lab P2S (68 900–68 990 ₽) — an update to the P1S released in 2026. The same 256×256×256 mm build volume, but 600 mm/s and 20 000 mm/s², 5-inch touchscreen instead of the cross, quick-release hotend without screws, 1080p camera with AI detection of “stringing” and active camera cooling, enabling PLA printing with the door closed. According to Tom’s Hardware measurements, extrusion force increased by about 70% compared to the previous generation.
Bambu Lab X2D (88 000–88 999 ₽) — the most interesting at this stage, because here two nozzles appear: the main direct-drive nozzle and an auxiliary Bowden-style nozzle for supports or second material, with mechanical switching. Print area — up to 256×256×260 mm, and in the zone accessible to both nozzles, 235,5×256×256 mm. The camera actively heats up to 65 °C in heating mode and is blown by external air in cooling mode. The design aim is to print supports with a different material without color change.
Bambu Lab X2D with two nozzles. Photo from Bambu Lab announcement
Nearby — Creality K2 Pro (94 900 ₽). This is where the decision starts to hinge on ecosystem and part availability, not just specs.
Combo variants: A2L Combo 58 500–58 999 ₽, P1S Combo with AMS 66 999–69 900 ₽, P2S Combo with AMS 2 Pro 96 900–96 990 ₽.
Step 4. More than 100 000 ₽ — two nozzles and a large bed
Here you move for a concrete reason, not “just to have it.”
Reason 1 — two independent nozzles: they remove the main pain of single-extruder multi-material and color-change waste. Reason 2 — volume: bed 320 mm per side. Reason 3 — active chamber heating for nylon and polycarbonate.
Retail benchmarks: Creality K2 Plus — 127 900 ₽, Combo with CFS — 157 000 ₽; Bambu Lab H2S — 143 900–143 999 ₽ (Combo 169 900–169 999 ₽); Bambu Lab H2D — 218 900–219 900 ₽ (Combo 238 900–239 900 ₽), and laser module variants at 10 and 40 W go above 300k.
Separately стоит Prusa CORE One — a closed CoreXY 250×220×270 mm with active chamber temperature control up to 55 °C and nozzle up to 290 °C, officially $1199 assembled and $949 as a kit. In the Russian market it is rare and priced high, but this is the only machine in the list with open firmware, where reflashing does not void the warranty — if repairability and independence from the cloud matter to you, this is a strong argument.
Prusa CORE One — the only machine in the selection with open firmware. Photo from Prusa Research announcement
About the cloud and local mode
Bambu Lab, Creality and Anycubic by default tie into their apps and cloud accounts. All have a local network print mode, but the feature set is pared down, and firmware updates sometimes change the rules. If the printer must operate in an isolated network segment, check this before buying, not after.
Step 5. They say resin is not an upgrade, but a different tool
SLA printers deliver detail unattainable by FDM: the Elegoo Mars 5 Ultra (32 900 ₽) has a 9K 7-inch screen and 18×18 µm pixels with a 153×78×165 mm print area. At this level, Anycubic ranges from the Photon Mono 4 10K (29 900 ₽) to the Photon Mono M7 Pro (51 900 ₽) and the M7 Max (79 500 ₽).
Elegoo Mars 5 Ultra: print area 153×78×165 mm, 18 µm pixel. Photo: 3DMall
But buying resin “in addition to plastic, since it’s cheap” is a bad idea. This is a fundamentally different process: liquid resin, isopropyl alcohol for washing, UV debond/curing chamber, nitrile gloves, exhaust, waste disposal. A cured part cannot just be picked up by hand. If you don’t have a dedicated ventilated room, go for FDM.
Summary table: base models by tier
Model Kinematics / enclosure Build area, mm Nozzle / bed Price in Russia, ₽
Bambu Lab A1 mini Core-less, open 180×180×180 300 / 80 °C 19 999–21 900
Creality Ender-3 V3 KE Core-less, open 300 °C ~27 900
Bambu Lab A1 Core-less, open 256×256×256 300 / 100 °C 29 999–32 900
Anycubic Kobra S1 CoreXY, closed 250×250×250 320 °C 30 300–39 800
Elegoo Centauri Carbon CoreXY, closed 256×256×256 320 / 110 °C 35 000–52 000
Bambu Lab A2L Core-less, open 330×320×325 300 / 80 °C 44 900–44 999
Bambu Lab P1S CoreXY, closed 256×256×256 300 / 100 °C 49 900–49 990
Bambu Lab P2S CoreXY, closed 256×256×256 300 / 100 °C 68 900–68 990
Bambu Lab X2D CoreXY, closed, two nozzles, camera up to 65 °C 256×256×260 (total zone 235,5×256×256) 88 000–88 999
Creality K2 Pro CoreXY, closed 94 900
Creality K2 Plus CoreXY, closed 127 900
Bambu Lab H2S CoreXY, closed 143 900–143 999
Bambu Lab H2D CoreXY, closed, two nozzles 218 900–219 900
Prusa CORE One CoreXY, closed, chamber up to 55 °C 250×220×270 290 °C $1199 officially
Elegoo Mars 5 Ultra Resin, 9K, 7-inch screen 153×78×165 32 900
Anycubic Photon Mono M7 Pro Resin 51 900
A dash means I did not verify the spec from the source, and I won’t present it as tested — please confirm with a seller. Prices are the Russian retail as of 18.08.2026 from igo3d, 3DMall, ForOffice and the official Anycubic Russia store.
Resin premium addons
Kit Price in Russia, ₽ Premium over base model
Bambu Lab A1 mini Combo (AMS lite) 36 999 ~15–17 тыс.
Bambu Lab A1 Combo 46 999 ~14–17 тыс.
Bambu Lab A2L Combo 58 500–58 999 ~14 тыс.
Bambu Lab P1S Combo 66 999–69 900 ~17–20 тыс.
Bambu Lab P2S Combo (AMS 2 Pro) 96 900–96 990 ~28 тыс.
Creality K2 Plus Combo with CFS 157 000 ~29 тыс.
Where to buy and what you end up with
Prices vary widely. Elegoo Centauri Carbon can cost 35 000 in one store and 52 000 in another on the same day. Check at least three marketplaces before paying — it’s literally fifteen minutes that could save you fifteen thousand.
“EU version” in the name refers to the plug and certification, not quality. See exactly what you get and who provides the warranty: official distributor in Russia, a store with its own service team, or a marketplace seller who will send you to the manufacturer in China for repairs.
Combo packaging is not always obvious. Sometimes the filament feed box is present, but there are no coils; sometimes “Combo” at one seller and “with AMS” at another — these are different sets. Read the kit contents, not the name.
Do not buy a used printer “from hands, printed twice” without personally inspecting with a test print and a part stamped. Clogged nozzles, a jammed extruder, warped bed glass, and a dead LCD screen on a photopolymer printer (its lifespan is finite and measured in hundreds of hours) are not visible in photos in ads.
What you’ll need to buy in addition to the printer
People forget about this, and the kit ends up 10–20% of the machine cost.
  • Plastic. Domestic PLA — about 1,800–2,400 ₽ per kilogram spool (per the Bestfilament price). Imported branded filaments are noticeably more expensive. Budget for 3–4 spools for the first month.
  • Dryer or hermetic box with silica gel. PETG, nylon, and TPU absorb moisture from the air, and wet plastic yields cracking, bubbles, and a jagged surface — this is the most common reason a “printer broke” for beginners.
  • Consumables. Spare nozzles (copper wears out after hundreds of hours, and more so with fiber-reinforced composites), glue stick or adhesive spray, isopropyl alcohol for cleaning the bed.
  • Space and power. The printer takes up more space than its dimensions suggest: needs access from all sides and extra height for a spool on top.
The first 72 hours
The order here is more important than speed. A common rookie mistake is to immediately print a complex model from the Internet on unfamiliar plastic, end up with a mess, and not understand what exactly caused it: geometry, plastic, profile, or calibration.
The correct sequence is from known to unknown. First the factory profile, factory filament, a simple part. Once you have a benchmark, change one variable and see what changed.
Separately about the first layer: this is the only thing worth learning to read with your eyes. The lines of the first layer should fuse along the edges into a solid sheet, not bubble at the edges (nozzle too low) and not have gaps between them (too high). Adjust the Z-offset in steps of 0.02–0.05 mm, not by “eyeing a bit more.”
We already have a detailed teardown on calibration on the related hardware — Klipper calibration order: seven steps you must not rearrange. The logic is the same: first mechanics, then thermals, then flow.
What reviewers don’t write about
FDM printing is heating plastic to 200–320 °C in a room where you breathe. This isn’t panic, it’s a measurable fact.
The UL Chemical Insights report on the impact of 3D printing on indoor air quality provides specific figures: particle emissions differ by filament by orders of magnitude — from 1.28×10⁴ to 3.42×10⁸ particles per hour, and by mass, ABS gives the most (4.46 µg/h vs less than 1 µg/h for PLA). In the study, more than 200 volatile organic compounds were detected; among them, styrene, toluene, xylene, formaldehyde, and ethylbenzene are associated with ABS. In school room samples, formaldehyde concentration exceeded the target level and reached up to 20 µg/m³.
The practical takeaway is simple and not dramatic: ventilation works. Printing PLA in a ventilated room is acceptable. Regular ABS/ASA printing should be done only in a closed enclosure with a filter, preferably not in a bedroom. There is a specialized standard — ANSI/CAN/UL 2904 for measuring emissions of 3D printers; some models are certified under it, and it is the only objective metric in this field.
With resin, it’s stricter. Photopolymer is a sensitizer: contact with skin can cause an allergy that may not go away. Nitrile gloves (not latex), goggles, a separate ventilated space, rinsing with isopropyl alcohol in a closed container, and proper disposal of used resin and alcohol — not down the drain. Do not pour uncured resin into the sewer.
Forum topics related to this
Two questions for those who already have a printer set up. First: which model and after how long did you realize you bought the wrong one — and what exactly was missing? Second, a more practical one: who prints ABS or ASA at home — how did you solve the exhaust issue, and did it become noticeably better after installing one?
